scamp
I plugged a Satan's Hollow boardset into my Tron and started it up and all I see is a white test grid.
I've done the following:
1. tried another set of ribbon cables
2. pressed the reset button
3. performed the dip switch test (solid yellow light..means ok)
Any thoughts?
I have another Tron boardset that I could potentially swap boards to try to isolate which board has the problem (will that even work? I believe they are interchangeable)
Thanks!!
Any thoughts?
Thanks!!
