So I've been working on it 14 inch Sanyo which is very similar to its 20 inch big brother. I got it and it didn't work so what I've done to it so far has been changing q901, changed IC601, changed all the capacitors, HOT, B+, and I checked a couple of the resistors while in the process. It was spitting out 137VDC before I change the HOT now that I've changed it, it's only spitting out 7VDC. I'm unable to adjust it any higher or lower. I don't know what the next step is here looking at some of the charts it tells me to replace or check q901 and I've already done that. I don't know how to proceed from this point other than going back to the q901 and triple checking it again. All the parts I've got have come from Peter at APAR
Here is a picture of the q901 transistor. It's not labeled as such on the board but that's the best I could figure it was as you can see I've used new thermal paste and an insulator
