Sanyo Question for the big brains
KRJMN
Minnesota
Nintendo vs. monitor new parts: HOT, flyback, cap kit minus the filter cap, IC601, Q901, B+ pot.
B+ still does not adjust to 108, works then jumps to shut down. What did I miss? What does the filter cap do?
Allright, I turned down the brightness and checked it again and no change. I also replaced the filter cap and that didn't make any difference either. I have replaced every single part on monitor board that people talk about on here. Monitor goes from 98 to 140 and shuts off. Maybe I bought a bad voltage regultor? Any Ideas what to check?
suspect faulty IC601
There have been issues with IC601's from Bob Roberts
Do you still have the old IC601? If so, re-install it and test again.
