Sanyo on my DK
Talon2000
Princeton, Texas
Fresh cap kit, replaced blown flyback.
So I'm now getting b+ and a picture.. woohoo..
But I can't seem to get the picture to sync. I've adjusted the holds so I can partially see what I've got. Swapped monitors so I know it's the monitor.
Little lost on these Sanyos.
Yeah found the little guy hiding. Looks like it need replacing when I touch it (with a plastic adjustor) the screen goes black. So it's probably bad.
yea replace the pot and look for broken traces in the area.
i had the same problem on one of mine.
Peace
Buffett
If it is the 3k pot in the center of the chassis then it is an obsolete pot.
I found one from a company in Japan that was rated at .01w instead of .02w
but it worked just fine.
It is a bit smaller than the original one so I had to spread the legs a bit to get it to fit.
Here is a link to that pot,they have tons of great stuff for great prices and fast shipping. http://www.taydaelectronics.com/pot...ers/3k-ohm-trimpot-variable-resistor-6mm.html
My monitor would freak out every time I touched the horiz. pot and after I replaced it the pic came up.
Ok, well as I'm sure those familiar with the EZ20 know the 3k pot is not an easy find. So instead I used a 2k as some other have tried. So I now have picture.
However there is a slight wave to the whole picture. Just enough to know it's there.
Thanks for the help on this one. I rarely work on monitors.
