tester007
Got a sanyo that looked washed out so i recapped it. Everything looks great on it except there is no adjustment to the green. I can turn the pot on the neckboard and it does nothing. I swapped the transistors around on the neckboard for red/green and no change. Also swapped the green and blue wires on the neckboard and the blue is adjustable (fed green input wire) meaning there is a green signal coming through, but the green pot (blue signal wire) does nothing even though i know the signal on the blue wire is fine.
So i believe its either something on the neckboard other than the transistors, or the tube. I have a rejuvenator and the green gun checks out fine.. Could the gun still be bad?
