SANYO F5024 WILL REPLACE F5039 for SANYO z2aw chassis NO PROBLEM. SAME SPECS.
arcadecup
Lots of people have been asking if a f5039 flyback replacement was out there.
Customer sent in original yoke & board and it turns out even though the yoke has a different # the specs are exact to the ezv.. Readings were spot on.
With a F5024 used as the replacement for the F5039 labeled flyback everything is working perfectly in spec.
HIGH VOLTAGE, CHECK.
current draw, check
temps, check
collector pulse time & vpp, check.
CASE CLOSED. F5024 = F5039.
Wow, that's good news. Back when I needed a replacement flyback for one of my 20-Z2AW monitors, I was told by Bob Roberts that the F5024 wasn't compatible (everyone else I asked said they didn't know one way or another). I ended up finding a used F5039 flyback for it.
It always seemed strange to me that they would use flybacks that were functionally different, given that the 20-Z2AW and the 20-EZV are essentially the same monitor.
I wonder why they bothered with different part numbers? If I remember right, the location of the screen and focus pots are different; so that's probably the only reason for the different part numbers.
Maybe I'll get brand new flybacks for both my 20-Z2AWs. I wonder if that will help with the focus. Neither of them focus very sharply.
