Sanyo EZ20 problem
jsquared
South Bend, Indiana
I just capped a Sanyo EZ20 and since then during initial turn on, exeverything looks great. After about 10 sec. the left side gets shakey and eventually the whole screen scrambles. I tried another board on this monitor and same results. So I know its not the pots on the game pcb. I also tried this game pcb in another cab and it works fine. I tried adjusting the pots on the control pwb and nothing. Any suggestions? BTW I installed the cap kit found on mikesarcade website.
Here is a pic
You're just losing sync is all. There's a pot located on the monitor chassis (darn near in the middle) which should straighten that out for you. Typically labeled VRxxx
