Sanyo EZ20 Horizontal line
pacray
Erie, Colorado
I'm not getting any vertical deflection, horizontal line only. Do I need to replace the transistor on the heat sink?
Check to make sure the service switch in the center of the chassis isn't flipped....
Okay, put in a COMPLETE cap kit and check it for cold solder at the time. You can measure those vert transistors while you have it out.
Oh yeah, and make sure your yokes plugs are on good....
Yoke wires are tight.
It was after the cap kit that the problem began. I plugged it in and after about 2 seconds I saw smoke rising from the area in back between the flyback and the tube. I turned it off, removed the chassis, and checked for solder bridges. I found possible issues and put it back to get only the horizontal line.
I will remove the chassis, check for cold solder joints and test the Xistors.
