I've searched, but cannot find a similar problem here.
I just recapped the Sanyo EZ20 in my Punchout machine, and when I re-installed the chassis and fired it up all the colors are washed out. It appears to be too bright, so I turned down the Brightness on the control board all the way counterclockwise. This made a very slight improvement, but the screen was still way too white. I went to the flyback and adjusted the Screen control. I could make the problem worse by turning it clockwise, but it did not seem to get better even with this control turned completely counterclockwise.
Any ideas where I should start looking? Also, is there a procedure, or proper order, for adjusting the color controls?
