Sanyo EZ swap
copious
Sparta, New Jersey
I am swapping out a capped EZ for a not quite perfect EZ and the wireing is slightly different. The newer PCB has 3 additional wires (2 plugs) these look original I just don't have a home for them.
One is a single red wire from R232 ?
The other is 2 wires located on the same side as the power input.
If these are not need then I'll coil them up I just need to know what they are for.
The single red wire is indeed the power wire for an inverter board.
Not sure on the other 2 though.
A pic might help identify them.
