cwales
I know this is talked about a lot on here, I have a Sanyo EZ that I capped.
There is fold over on the right side, the pots on the board do not fix it. Well, you can get rid of the fold over but the right side is still squished. It's as if DK Jr gets really small if you go to 0the right two vines on the first board. I swapped the board into DK, it looks great. Power is 108 on the monitor...
Cap 407 is good, I even changed it again just in case since I had an extra, it's exactly the same with both in.
I also noticed that the brightness isn't quite the same on left and right sides on the screen, it's brighter on the right side. Like a line separating the brightness. I will post pictures tomorrow, my camera is at home.
