sanyo ez monitor just recapped...still have blue screen..etc
vader1979
Donor 2021, 2023
bismarck, North Dakota
Ok...just got my chassis back from buffets from being recapped. Before I sent in my monitor had a blue background throughout and had vertical lines going thru monitor...they are close together on left side and get wider as they go to the right. They are solid and don't move. The cap kit did not change the tube once installed...I have already ruled out pcb and power supply...was told I need a rejuvenate...any other advice or possibilities?
There are 2 other brightness controls on that chassis. One is just about in the center of the monitor chassis, the second is next to the volume control. Did you try adjusting those?
I'm no expert either, but I am trying to work through an issue of my own with an EZ20 monitor.
Honestly I haven't even touched it yet....didn't want to mess it up more....will try tonight...so adjusting those could possibly get rid of the vertical lines as well?
After ALOT of tweaking....I finally got it set right....I had to tweak every pot to get it right....thanks for the helping guys....!
