Sanyo EZ chassis and amp board
chris25810
lake elmo, Minnesota
This is clean with new caps on the main and audio board and also has a brand new flyback. The neckboard was cracked but it's been repaired to the point where the repair is stronger than the rest of the chassis. As long as you push the neckboard on from the middle like you're supposed to, you'll never have a problem with it. $135 shipped, send a pm if you want it. BTW, this does not have the wire for the inverter.
Also have a clean recapped GO7 19" with a good width coil and original flyback for $65 shipped
