it's actually a 20-Z2AW. the last time I asked about it, nobody replied. which makes me wonder, do those take the entire same cap kit as the EZV? the bottom monitor I did on my PC-10 came out looking fantastic after I adjusted it since the colors were all messed up after capping it (monitor was abused by heavy brightness, etc.), this one is for the top monitor. Bob says for these you just use the standard kit, and so I just left it at that. if so though, I have deluxe kits that I can pull the extra caps from to make them complete.
I made a mistake when I put this monitor back together, you know the forked ground terminal that screws to the frame? I forgot to reconnect that, and I don't even know why. it went into HV shutdown immediately, I think the B+ was about 130. reconnecting that made it turn on, but now the B+ is at about 122V
so yeah, it works now, but it does the hula.
are the parts interchangeable between this and an EZV? also, what is the red wire for that goes to the inverter board? I tried hooking an EZV up direct and it pops the small fuse, I read that running without the inverter can do that, and the EZV lacks the red wire that goes to the 3 pin header at the top of the inverter board.
EDIT: to reiterate, this is for a PC-10 dual monitor, hence the inverter board stuff.
