Sanyo EZ 20 recap trouble
fishookred
Albany, Oregon
I accidentally burned the board at one of the caps. The rest are fine. Is my board destroyed now or is it Ok?
everything is fixable and there are different ways to fix different types of damage. clean it up and see the actual damage and post a clean picture.
You can see the spot next to r301 on the board. I'd rather not take the cap out or I may never be able to get it to stick again. If that one spot was heavily damaged would it affect the rest of the board?
just run a wire connecting the affected traces if there is a break in continuity
Might have to slap and tickle that spot with a jumper.
Have to scratch the solder mask away on that trace and jumper to the leg solder point
