Okay so first problem is the screen size. there's about 4" on the top and 4" on the bottom that is unused. None of the adjustment pots on the neck board do anything. The adjustment pots on the inverter board, and the other board attached to the chassis work, but do very little adjustment for V-size
My other problem is the tube does not display the color Blue. The cab has all new wiring and is wired jamma. I believe this was the problem with the monitor the seller was talking about when he said "The screen isn't great" I know all the wiring and connections are good.
any help would be appreciated.
