barrysfarm
The service switch has been switched back and forth several times. It is currently switched so that it pointing to the back of the monitor, toward the B+ adjustment.
check the solder joints and traces for IC601
Did you check for open R473 & R239 ?
I have an extra IC601 that i got from BR. What are the chances that the current one is blown? Honestly I don't even know what that part does. Can it be blown?
I got a spark and now B+ is stuck at 140v, and I get no image what-so-ever.
Any other ideas?
Right by the b+ adjustment. It could have been the fuse. Once it sparked, I turned everything off and walked away for a bit.
I'd sure have to asume your tube and yoke are good. If the "new" board doesn't work out for you might I suggest you buy a Wei-ya chassis??!
If it's a Nintendo game being used you'll also need to buy an inverter board but I've purchased several lately and they are easy to install and work like a champ.
Future advice, Chad here on the forums is a chassis repairman. I'm sure someone can link you to his website. He is great at it and I never had any complaints with his service.
Kevin
The new chassis can be plugged directly into an outlet - otherwise buy a standard ISO to use.
http://alvaamusement.com
I believe my last chassis was ~ $75 shipped.
Alva sells them cheaper than 8liners.com
Here's a good read to help you order your chassis - you need to measure the yokes impedance:
http://www.8liners.com/datatech/monitor.html
Keep in mind Nintendos colors are inverted and the audios power is fed from the chassis so you'll need this as well:
http://mikesarcade.com/cgi-bin/store.pl?sku=NININVAMP
