ch0de
My sanyo 20ez is from a Popeye cocktail cabinet. I just re-caped the monitor to get rid of some crunching at top of screen (score and high score were crunched) and there was shaking.
After recap (Arcade shop extra parts kit) The screen is bright and no more crunching. But i get non stop rolling. Sometimes i can get it to sop for a bit using the V-hold pot, but it starts again. When i do get it to stop sometimes it's stopped with the screen split half way,
Test switch is set to normal. I've tested the Pots for v-size v-hold h-cent h-hold and they all seam to show proper resistance as i turn the pot, and hold that resistance were i stop.
The b+ is right at 108.6vdc (i adjusted after re-cap)
I re-flowed all my caps to make sure, Also ran some continuity checks,
Any thoughts?
Thanks in advance.
Any thoughts?
Thanks in advance.
