Sanyo 20EZ problem
If you think that I would just try it, was very quick and easy. Cheap part and will take longer to heat up the soldering iron than to do it. If it doesnt work just remove it.
I would have to pull my monitor out of the cab to get a photo as access is super tight. From memory I traced the yellow and green cable from the yoke down to the chassis and then soldered the resistor between those. I initially tried it at the yoke and it didn't work.
If you need I can pull out to get a photo but I think you'll be fine.
