Sanyo 20ez Monitor Color Missing?
MrWaffles
Coshocton, Ohio
Ok so here is the story. My buddy and i capped and redid the filter on it, had done a few before with no issues. The monitor was way and had the jailbars but the blue color was still on it along with all other colors. After the cap kit we install the monitor again and the blue color is completely missing, along with The ladders are neonish green and the white score lettering is semi yellow. Will try getting a picture up soon.
Our two opinions say its either the blue pots or the tube randomly went bad within an hour?
Is the tube shot or do you guys think the pots could be bad or is there something we are missing?
Try checking/adusting the color bias pots on the neck board and on the inverter if you've got one. Try tweaking each one individually and see if it affects the picture. I doubt your tube went bad. Also check the transistors on the neck board . You could have broke one leg or knocked one loose.
We tried each pot the only ones that dont affect anything are the blue ones... Thats why i am unsure if the tube went bad...
did you inspect the neck board for broken/bad components? also are you sure all leads to the neck board have good connections? Also check to see if the neck board is seated properly.
Not yet will check when i arrive home in a few days... On work trip at the moment. Thanks for the fast responses at such a late hour.
