Sanyo 20EZ. HV shutdown, no neck glow. Found a cracked neckboard
I am working on a recently acquired Sanyo 20EZ that has a B+ of 130, no neck glow/picture and after examining the neckboard, found that it is cracked in two. Yikes!
I tried to find and repair/jumper every broken trace and checked for continuity on the neckboard. I thought I repaired all the issues. With no neck glow, do you suspect that this is still a problem with the neckboard and something I haven't located yet or do you think it is something with the main chassis/tube?
Thanks for the help!
Torin
Torin
