ronzal New member Joined Jan 1, 2006 Messages 960 Reaction score 3 Location Illinois Jun 29, 2012 #1 im having a problem with the monitor coming on the white rectangle piece in the pic dont now what it is but gets hot and pops fuse any ideas thanks Last edited: Jul 20, 2012
Buffett Well-known member Donor 2012-2013 VAPS Joined Mar 12, 2010 Messages 10,991 Reaction score 263 Location Manassas va, Virginia Jun 29, 2012 #2 something in the circuit is probably shorted and causing it to get hot. or it may be out of spec due to being cracked. either way you will need to test/look at things to see wat's up. has the chassis had a cap kit yet. and what fuse blows the small on the big one or both. Peace Buffett
OP OP ronzal New member Joined Jan 1, 2006 Messages 960 Reaction score 3 Location Illinois Jun 29, 2012 #3 i did cap it didnt make any diff and it is the small fuse that pops
Buffett Well-known member Donor 2012-2013 VAPS Joined Mar 12, 2010 Messages 10,991 Reaction score 263 Location Manassas va, Virginia Jun 29, 2012 #4 check your H.O.T it may be shorted. its the bottle cap transistor by the fly. Peace Buffett
Buffett Well-known member Donor 2012-2013 VAPS Joined Mar 12, 2010 Messages 10,991 Reaction score 263 Location Manassas va, Virginia Jun 29, 2012 #5 did you set your B+ to 108vdc. Peace Buffett
OP OP ronzal New member Joined Jan 1, 2006 Messages 960 Reaction score 3 Location Illinois Jun 29, 2012 #6 i will check the hot and no i havent set the B+ because i dont now how im more of a part swapper any hints on how to would be great and i will do a little reading thanks
Buffett Well-known member Donor 2012-2013 VAPS Joined Mar 12, 2010 Messages 10,991 Reaction score 263 Location Manassas va, Virginia Jun 29, 2012 #7 do a search in the monitor forums it has been explained many times by me and countless others in great detail. Peace Buffett
OP OP ronzal New member Joined Jan 1, 2006 Messages 960 Reaction score 3 Location Illinois Jun 29, 2012 #8 thanks i will do that
