FS Parts: Sanyo 20EZ for sale $75
RidicRick25
Raymond, Iowa
Just capped it.. video and audio. Rejuvenated it. Rejuvenater says everything is in good order. When I load up Super Mario Bros Vs the colors are all messed up during play and intro screen... but when showing scores the colors are perfect and quality is like new! Not sure what the problem is, probably an easy fix but I don't need the monitor now and someone else can use it for their Nintendo cab. I will not ship, must be picked up local. Thanks.
$75
Located in Waterloo, Iowa.
Do you have the correct PPU chip for SMB? It could be that it's not correct as it defines what colors to output on the PCB.
Yep, I got the correct PPU and I even put another SMB chip set in the PCB and still the same result. Also tried all 3 of my other PCB's with my chips, and different PPU's just in case and still the same result. I gave up on the dam monitor and took it out. But thanks for the suggestion.
