Sanyo 20EZ and Sharp XM-200IN INVERTED
78whiteorbs
North Carolina
Just had a me.ber rebuild nothing these monitors for my player choice 10.
A 20ez bottom and a sharp on top.
Im hooking something up wrong here
Colors are inverted on 1 screen and looks like sync issue on the other.
If I swap the video molexs and white/brown wire the pro lens follow the video source.
See pics ...what am I doing wrong here?
index.php?action=dlattach;topic=74778.gifLittle Video wire is plugged into wrong header on the inverter board on the ez.
Just fixed the sharp there was an inve E sign switch on the chassis...done .
Now the other screen is scrambled
Flipped the inversion switch on the sharp and it's good to go.
Now the colors are right on the bottom EZ it just looks like a sync issue.
Adjust horizontal hold for the scrambled monitor. It is one of the pots on the main chassis, refer to the manual for location.
Found it and it locks in now ez20 doesn't have horizontal hold in same position.
I'd like to put the ez20 on top cause it has little punchout burn while the sharpnis burn free. When I swap connectors I now need to adjust h hold on the ez20. Where is that at?
