sanyo 20 ezv
fast-ed
potosi, Missouri
i bought a used and clean chassis and installed it in my dk. picture was fine except it wiggled up and down ever so slightly. read some of dokerts post and i adjusted the b+ pot to 108 volts dc and it looks perferct, but i did notice the picture shaking every 5 seconds or so from right to left about an eight of an inch, not bad but it bothers me. any help would be appreciated. thanks, ed
Try the H hold
Edit: adjust V hold
Try adjusting the the V hold Pot slightly on the monitor. If that doesn't work, you Could also try slightly adjusting the left right pots on the DK pcb
I had the same issues too and the pots are just crap. If you find that the vhold is wacky - but fixes it.. then you can replace the pots.
