DaveyPocket
The original problem with my monitor was that there was a red haze on the screen and some raster was visible (only red). If the red adjustments were turned down, it still showed. I tried disconnecting a few things to see what would happen (removing the transistor going to the red connection on the CRT, disconnecting the pin 8 (which controls red I believe)). After trying all of that and reconnecting what I had undone, red stopped showing up. Also the resistor going to pin 8 on the neckboard broke in half, I'm assuming this could be a problem?
Any other ideas?
Any other ideas?
