Sanyo 18-Z2AB
MackAttack
Donor 4 years: 2014, 2016, 2018, 2024
I am working on a Donkey Kong Junior cocktail. The main 5 AMP fuse on the power supply blows anytime it's plugged—unless the monitor is disconnected… so must be something with the monitor. I checked the continuity on the degaussing coil and it's fine. I finished a cap kit and checked the HOT (2SD869) while I was at it. The base and emitter are shorted. Would that cause the main 5 AMP fuse to blow?
I supplied a couple pics for kicks.
