Sanyo 14" DK mini
thebman80
Wallingford, Pennsylvania
Ok worked on this thing the last 2 days. Got a cap kit together from a fellow KLOV'er at Crabtowne get together we had on Saturday. I missed like 2 small caps on the chassis for the kit. So what happened is that I installed what I had prob 99% of the caps on the monitor. The monitor came on couldn't get a stable picture for the life of me. Measured the B+ was around 125v tried to adjust then it jumped up to 130v 130.4v area and up and down to 128v. Pulled and tested q901 tested fine but it back in fresh heat sink paste and what not. Tried replacing B+ pot with another form spare parts chassis nothing... Get no picture now, no neck glow, guess I will change the old B+ pot back but I don't think it will change much.
So where should I go now? Its so late been at it all night and I'm a little burned out. So went from nothing to an unstable picture then back to nothing all in one night lol. should I just start over get some bob roberts parts or just keep plugging away at it?
@#$% this monitor is suck a bitch to cap!
just like in the Sanyo IC601.
i do not know what you have in there but it may have failed up and is keeping it in shutdown.
that is possibly the reason you cannot adjust the B+.
give the chassis a good re-flow and check your work to be sure there is not a solder bridge anywhere.
re-check all the caps for proper value and polarity.
Peace
Buffett
