Sanwa 27" Completely Dead - Need Help
neopolss
Donor 6 years: 2013, 2016-2020
Topeka, Kansas
I'm trying to bring back a dead Sanwa. It's a 27z21c or PM1745 Chassis type. There isn't much out there for it. If anyone has a schematic it might help. It was playing absolutely fine, and then would not come on the next day. It has 120v to the chassis, beyond that I have no idea. Fuses test good. I compiled a list of caps and ordered from Mouser, recapped the entire chassis. Still nothing. I see no charring, no sign of anything burned, nothing at all. It's a very clean chassis. I resoldered the flyback, but nothing. Any help? I will post the cap list from this monitor if it will help others in the future.
Sanwa 27z21c PM1745 Cap List
Location Voltage uf
107 16 10
310 16 220
408 16 330
103 25 47
814 25 220
109 25 220
110 25 1000
406 35 47
419 35 47
305 35 100
313 35 100
813 35 220
308 50 1
407 50 1
101 50 1
102 50 1
424 50 1
415 50 4.7
414 50 10
417 50 10
416 50 10
108 50 10
811 50 33
426 50 220
314 50 330
312 50 470
808 160 100
812 160 100
909 200 4.7 neck
111 200 47
805 200 680 filter
427 250 0.47
441 250 1
428 250 1
Does anyone repair Sanwa chassis? I've recapped it and nothing. Getting voltage but no HV sound at all. I'm at a loss.
This is an older thread, don't know if the OP solved the problem but there's not much on these PCBs out there so posting in case this helps.
I have a pair of Time Crisis 3 machines with the PM1745 chassis. One appeared to work, replacing the capacitors is a good route considering the year manufactured dates for each board. The other had an arcing flyback, so I purchased a replacement and a resistor smoked when turning it back on (R302). Appears transistor Q406 had problems and making IC301 questionable. It appears a few transistors had been replaced in the past. So suggestion is check the ICs, transistors, and inspect for any burnt resistors.
