Shift_ME
before I get roasted for not using "search". I did, many may times
So heres the background, I have 4 rush machines, 2-rush the rock, 2 rush extreme.
1 of each work.
two confusing issues one for each machine.
1st - rush the rock.
Problem: game plays, boots and runs no problem, but the streering is "loose", meaning I turn the wheel and it barely turns the game.
What I've tried :
- swaped out the steering I/o, made no difference, throwing the "bad" one in the working machine and the steering has no issue.
-checked potentiometer, 5k yada yada, reads almost perfect. swapped a known good one in, same issue, barely turns the car when driving.
-power supply (thinking what the heck), swapped it out on a working machine and even turned it up a bit, again no difference.
-went into calabration and it reads 1024 to -1024 which is the same as the other and when do the test feedback the feedback is fine.
Any thoughts?
2nd problem
Other machine rush extreme.
powers up and plays no issue.
go into linked game, and on first car works no problem, but next time it "sometimes" reboots the game, thinking it may have to do with the cat5 cable link on the pcb? anyone ever heard of this, I did turn up and swap out power supplies but made no differennnce.
any thoughts?
1 of each work.
What I've tried :
Any thoughts?
2nd problem
any thoughts?
