GAMEOVER
San Fran/RTR conversion will not change speed when manually shifted
I recently picked up a RTR conversion sitdown that's not changing speeds when manually shifted.You can see it changing gears on the screen but it just red lines in every gear and stays at max speed of first gear.Gear shift tests good in test mode all gears are registering and shiftier is enabled in options.Works fine in auto but that's no fun.Any ideas?
