Sad to See this!!! Quantum
Zarloffson
MURRIETA, California
This is a Quantum that was converted to a Escape From Planet Robot Monsters. I dont know what the others were. They are too far gone.
There are a few parts on there worth saving - like the retaining bracket at the bottom of the glass bezel and the control panel, though it would have to be patched.
Still might be worthing trying to somehow save it even though it would require an insane amount of work and ton of parts. You can build an original quantum only if you have an original cab to start with. Plus it could be a low serial number.
I noticed a palm tree in one of the pictures...where is it?
That's true.. The cabinet looks to be garbage, but there are clips, screws, etc.. that are original. You could retain the upper back piece with the serial and have a portion of the original cabinet in the reproduction. Original brackets, coin door, marquee light fixture, wood frame for monitor..doesn't sounds like a lot, but beats starting from nothing.
You know, if this showed up at my door, I would take it on as a project. That being said, keep it far, far away.
Its in Alhambra California. I looked inside to see if they threw the quantum board in there, but no luck.
You can't expect to get that lucky...ha ha.
Seriously, an attempt should be made to at least rescue it. I live in the area. I sent you a PM.
Thanks.
