Rush the rock - no force feedback
solo742
Colorado
Ok, just got my Rush the rock/alcatraz edition back up and running.
Now the force feedback does not work at all. Everything looks like it is hooked up correctly, and the fuses on the motor board seem ok.
The two LED's on the bottom:
The one on the left (as you look at the board) is intermittently lit. The other is on, which the manual states means it is too hot. This happens right when the game it turned on. Which is hard to believe that it gets hot that fast.
Please help. The other parts of the game work fine, and I have the same "steering wheel fail" during calibration, but I had that before and the FF still worked fine.
Thanks,
Email [email protected] or reply here.
Jim in Mead, CO
Solo742
OK, nevermind. I just figured it out...
It helps to make sure all you wires are plugged in to the appropriate places. One wire wasn't attached the the power brick and once it was "voila!" the feedback works 100%.
I am very glad it was an easy/cheap fix.
