Rush the Rock - Link Problem with same chd image on both?
I seen an older thread where this was mentioned, but no definitive answer so...
I've got a pair of Rush the Rock that I'm in the process of converting over to compact flash because of HDD crashes - out of 4 drives I started with I'm now down to one - is there a known problem running identical drives in both while linked? ie: if I use the same .chd file on both, can I expect issues or ??
