Rush the Rock issue
Raiden_2112
Dallas, Texas
I have a Rush the rock Giving me no steering while drive unless i let off the gas.You can pick your course car and steering is fine.you drive and have the foot on the gas no steering, you let off the gas and you can steer.My battery is dead other than that.I just replaced the steering pot.Any ideas?
I had a similar issue with mine. My battery went dead and it lost the gas, brake, and clutch limit settings. The gas and clutch are not a big deal but the brake is. When you are playing the game are the brake lights on? You can enter the settup menu and calibrate these in one of the menus. I am not sure which one but you will probrably find it. After setting the calibration go back to game mode and hopefully that works. It will loose the settings once you turn the game off until you replace the battery. When you do replace the battery make sure the tab that holds the battery is bent tight to secure it. Hope this helps.
