Rush sit down 3rd gear doesn't work
Fatality83
manchester, Pennsylvania
I noticed that sometimes on my rush sit down when shifting into 3rd gear it sometimes thinks its in neutral. If you move the gear shifter in and out of 3rd gear it then registers. Any ideas what may be causing this problem?
Sounds like a sticky switch, I would take off the shifter and check, and while you have it out might as well lube it up.
Most likely just needs a little lubrication and possibly a new microswitch. No point in spending $80+ on a whole new shifter when it should be a fairly simple repair.
Could be the switch, also could be that the steel actuator is bent in or broken. I have encountered broken actuators on a few different RTRs. Bought replacements off epay.
