Rush 2049 Networking
SmooveJ
Donor 2016
Severna Park, Maryland
I recently picked up two Rush 2049 sit-down cabs, to go with the auction cab of the same game that I've been gradually renovating. The two new cabs are linked using the cross-connect adapter, and they're working great together. I understand that to use more than two games at the same time, I need to connect them to a hub. Does anyone know if that means any old ethernet bridge/hub, or is it a specific device I need to track down? Anyone have experience with this? All guidance appreciated. Thanks.
any old Ethernet hub/switch will work. Just make sure that all the games are running the save version software otherwise they wont link.
Just as a follow up, linking with simple network hub worked great. You just need to assign each cab a unique number through the game options menu, then run the network test on each machine at the same time. You should see each unit recognizing the other units in the test, identified by vehicle number. Kids love the head-to-head-to-head action. Appreciate the help.
