bvernaci
I'm having keypad issues on a Rush 2049. In the Controls Test screen, it behaves as if all buttons in the right-most column are being depressed simultaneously (see picture). I have tried connecting a known good keypad and also disconnecting the keypad connector altogether and saw no change in the test screen. The wiring looks correct as far as I can tell.
Has anyone seen this behavior before? I'm guessing I could measure voltages on the 7-wire keypad connector and compare it to a working machine. It's just that I'm a noob when it comes to that stuff. Any better ideas?
Thanks,
Brian
Thanks,
Brian
