Rush 2049 Error 8 code...
Brian12
Donor 2015-2016
Macon, Georgia
anyway to fix this?...this PCB was working fine. I loaned it to a friend and when I got it back dip switches were different...I could see the game screen and playing but it was on the wrong Res switch...
When i swapped the res switch back the PCB now stays on error 8 on the PCB "LED number display"...
only other thread I found was about a year or more ago and ppl said it was not fix able? Is this now still the case?
-Brian
should be the boot rom. U27. reseat it. it should be standard practice of pushing down and reseating all socketed chips on all of your games, really.
and reading my PSU guide so you don't go blowing your hardware up. this platform requires you to run no higher than 5.10V to the chips; going higher WILL burn the +5 contacts on the JAMMA edge.
just tried that, no luck....
every time game is turned on, PCB is on "8"
Did you ever fix your board? I just fixed a board with the same problem. I notice I could manipulate the board and it would boot. So I reflowed the board. Here's a video of what I'm talking about.
It's working again, it's the one in the left with the lite up marquee.
Hey nice necro bump!
I think we best channel the brain power of the universe for this issue.
Turn on, Turn up, and tune out to meditation until the universe shows the way....
