Another enthusiast posted over on the Arcade Game Repair Help Group!! on FB about trying to use a G07 in a Super Sprint. We told him that he can't use a G07 in a Super Sprint outright because it's a medium res game and the G07 is standard res only. However, I knew of a solution that WOULD allow him to use a standard res monitor in a medium res game. I made a video on it and will post it once it's done but for now, here's the solution. Basically, you're using a CGA/EGA to VGA converter to convert the medium res signal to VGA, then you're feeding the VGA to a VGA to CGA converter to output the proper standard res signal. The two converters combined will have roughly a 4 frame drop, which is completely inconsequential for games like NARC, Super Sprint, Paperboy, APB, etc. The end result is a completely usable monitor that will allow you to keep the machine 'original' and not have to go the LCD route if the game's medium res monitor is missing, destroyed, you can't fix it, etc....
