I am in need of some advice for a Rowe AMI model R-80, I was moving the on and off, volume, switches from the back of the unit to the front and pulled some wires loose and can't tell where they go, juke box does not work now, (i guessed on reinstalling the wires) I've attached a photo of the 'board' that holds the wires.
I did remove and replace the 'reel' so I could work on the wiring, could I have messed something else up, the 'scan' switch will also not make reel move.
I can wiggle the reel and it will rotate one revolution, but when I push a play select buttom it will not click and hold.
Thanks in advance.
Bill
Thanks in advance.
Bill
