rowe r92 no volume control for the cd player
ekeeb
Scurry, Texas
I can select the cd and it will play with no volume control loud.I have volume control on the 45s any ideas?Cant find my manuel either.Thanks Ed
Fixed with more light
I picked this up juke up awhile back,the cd changer didnt work but the lens was rolling around on the bottom of the changer so superglued it back on checked the changer out plays fine with the home system double check again and hooked back up same results plays loud no volume control so i started to unplug the conectors on the amp to see if it had a bad connector unplug where it should be conneted but the cd was still blaring wouldnt you know a little father down theirs a plugin for the mic,shit it was plug into the wrong input.Its amazing what you can see with a little more light.
Jump the gun,my bad.
well just got home and went to make adjustments of what i thought was going to fix it,sorry jumped the gun on my prevous post thats where its supose to be pluged in.Never assume and thats what I did.Its not fixed yet,my bad.Ill wait before i post next time.
Ok really its fixed
ok really its fixed,it seems the pins in the connector were in the wrong postion so when i connected it to the input output it made no differance in volume control now it all works with the pins in the proper postion.I was sure about the mic inpute until i found my manuel to verify where the cd changer pluged in with those dancing lights but to the outside pins oposite of the light kit.Now time for a beer and rammstien on the juke.
