rowe R-91 volume control
dewser
north fort myers, Florida
I went to use my juke and the volume is almost at the lowest setting.I can not get it to get louder or quieter.I changed the pot and still the same.Is there anything else I can try to get this to work.Im not sure if a transistor in the amp is bad if that would cause this or not
Hello dewser,
locate the volume control plug on the amp. if you short the following pins on the amp it will give you full volume assuming there is not a fault on the amp:-
Pin 1
Pin 3 (normally not a wire into this location)
Pin 5
Regards
Alan
Alan Hood
ami-man
UK
Hello Dewser,
Yes that is correct link them out so that on the amp the volume connections 1,3 and 5 are all connected together.
We use a test volume control when we test these using a standard 10k ohms log pot, one end goes to pins 1 & 5 and the wiper goes to pin 3.
Regards
Alan
Alan Hood
ami-man
UK
