Hey guys. I aquired a Rowe/AMI MMCD3 juke for $75. I don't think I did bad, but then again, I might not have done the best either lol.
Everything on it works, with the exception of the main thing. It doesn't play CDs. The amplifier works, the pages turn, the display works.
When I first plug it in, it passes tests, then says RAM ERROR 1, may need to replace CCC EEprom. then, it allows you to insert quarters, select a song, etc.
When the CD is grabbed from the 100 disc mechanism, it lays it down, spins it (slowly?) for one second, then puts the cd back. It tries again, then fails.
I'm thinking it's the CD laser assembly. Am I correct? I'm getting no other errors. Or, is the CCC faulty too? looking through the small hole on it, it says it's version 4.4
any help is appreciated as always.
