Rowe change machine parts
scottz29
Donor 2024
Macomb, Michigan
Anybody have any Rowe change machine parts? I have a BC-20 and I'm looking specifically for the "Temporarily Out of Service" label, and the amber lamp, which I believe is just a plastic "light pipe". Inside, there is a bracket with a 755 bulb in a socket, and I presume the light screws on from the back, holding the bulb bracket in place.
Thanks...
-Scott
Scott,
I'd replace the original socket/bulb with an LED light. You'll have to build your own mounting bracket, but you won't have to worry about changing that bulb constantly.
Thanks...
-Scott
Scott,
I need the plastic piece that goes into the empty hole that's there now. I'd like to replace it with an original piece if possible. Not really concerned with the light bulb itself.
Did you find the part you needed?
I am about to part out a bunch of older rowe BC20 and BC25 changers
Eric
Cointech
