Rowe cd100c Tech question
cheesehead
Oregon, Wisconsin
I posted earlier about no sound. I found black wire on E1, Pink on E3, and Violet on E3. I've left black on E1 and moved Pnk and violet to the correct E6
I still have a loose Black and red wire. Accourding to the manual, These are the volume control wires and should be on terminal 3 and 4 on block above speaker terminals. I hope I'm correct ?
I also have a board that says JBS Automatic Jukebox Switch mounted right above the speaker terminal panel. It has 4 brown wires . One goes from jukebox terminal on board to E1, E6 on left speaker board. Other one goes from Jukebox(trip input) to right E1,E6.
What is the purpose of this board ?
Also the jumper is on "volume jumper" is the correct or should it be on dual channel ?
Thanks for all the help!!!
Do you have an external volume control hooked up now? If so the black and red wires from the machine's internal volume control should be left unhooked.
If no external remote volume is connected then the machine's internal (back-of-machine) volume control must be connected or there will be no sound. Black wire to common and red wire to "volume". That jumper is fine where it is.
The "JBS" accessory is a third party kit that (depending on JBS model) allows either the jukebox and a seperate sound system (like a background music system) to share common ceiling speakers or the jukebox amplifier to share inputs from the juke's cd player or an external music source.
In other words this units switches the ceiling speakers to either the jukebox or the background music. It does this by sensing the sound coming from the jukes cd player.
http://www.happcontrols.com/amusement/jukebox/95069800.htm
http://www.happcontrols.com/amusement/jukebox/95078400.htm
The JBS Automatic Jukebox Switch is made by:
Commercial Sound & Electronics
8507 Natural Bridge Road
St Louis, MO. 63121
Phone: (314) 428-4857‎
Fax: (314) 428-8810
Does not have a website.
Thanks alot Ken. You the Man !!!
I'm up and running. I'll try to repay the site with some tech help on something I'm more familiar with..Like pinball.
Thanks Again and have a great Thanksgiving
