Rowe CD100A crossover schematics
ACDNate
Donor 2022, 2024
Biloxi, Mississippi
Does anyone know if schematics are available for Rowe cd100a crossover assembly part # 61052701?
Have one that has failed in some way. There are no obvious signs of capacitor leakage or swelling. No cold joints. Header pins a bit dirty but not bad.
The coils show no signs of overheating. They do have resistance.
R2 and R5 are labeled as 20ohm 5w resistors but measure 3.4ohms and 6.7 ohms in circuit. Remaining resistors measure in spec.
Bonus question. The connectors in these look like molex kk .156. Those pins are too large to fit. What size/type of connector are these?
I don't have any schematics or anything but you might be able to get it repaired here. I had AB Jukebox repair redo my amplifier a while back but it looks like Bruce who ran that retired and a family member took over for him. But they might be a good place to check out and might be able to repair the board for you too
I've had those connector pins break causing loss of one channel. .156 pins are too big. Luckily the juke had spare pins in it.
What's weird is I found have the .156 and .100. I can't find anything in between
I'll check see if I have some to spare.
