BJones2
I'm having problems with a 100F an I am wondering if I could get pointed in the right direction.
Basically, when the cd drops into the player, it will spin a few times, and get picked up and put back in the carriage. It will try again and it does the same thing.
So far I have swapped the decoder, player, and computer with working ones from other boxes. They all work in the other boxes fine. The ones fromt he otehr boxes give the same result in the 100F.
I am guessing it is most likely a simple connection problem? When I purchased the box it worked fine but sat waiting for the title rack to be fixed, which I am working on as well. Now the sucker won't play!
On a similar note, I put new title cards in because 6 were originally missing. Is there a good way to align the bottom mech that moves the racks? The problem I am having is that the last and first title rack will 'hang' as in wants to move.
For example, on the bottom pages 00-11, if you try to go down, it will attempt to go down, but it will not move because it is at the end of the rack. It will try for a few seconds and give up. Messing with it I have aligned it to where it works properly up top; you can hit up and it won't do anything, and you can go down immediately.
On the bottom of the unit, there is a black piece that rotates and hits a switch. I am guessing that works like an end of stroke switch?
I am having the same problem with a unit from a 100G where someone had tried to align it with no luck. Is this just a horribly designed system? I hate to say it but the rack system in the 100-100Es are a lot better.
Any help would be appreciated!
Brandon
Brandon
