Rowe BC25 Changer Question
I was told it had to do with how it handled coins. I think it moves from 1 hopper to the next. Not locking out when 1 hopper was empty.
So that is the only difference? Hmm. Now I am not sure which to keep. Guess I will have to see which one is in better shap and just go from there. :)
Found an older post on a different forum.... MC apparently is the "maximum capacity" version.
Regular BC-25 you can use different coin types in each hopper. When one hopper runs empty, the machine shuts down. (not sure if you can run a regular BC-25 in MC mode or not. My BC-12 has that option via dip switchs).
BC-25MC is only a single type of coin in the entire machine, and if a hopper runs empty it just moves to the next one until all of them run dry.
-Hans
the boards are interchangable. I have a bc-9 cab with a bc-25mc board in it. I would say pick the look you like and put the board in it that you want..
