Rowe Ami mm6 repir
F. Cfield
Missouri
I have a Rowe AMI mm6 Bourbon Street that used to work perfectly fine. Recently, when I turn it on I can't make a selection. The buttons don't seem to register at all. I have reset the credit wheel, to no avail. Any input is greatly appreciated.
Thanks,
Steve
Do you have the manual set? You use the MM5 service/parts manual in conjunction with the MM6 service/parts supplement.
Yes, I have a manual. It seems like there isn't power after a transformer somewhere. Any ideas on where to start troubleshooting?
You should have two manuals. The MM5 manual is for basic troubleshooting and schematics. The MM6 supplement is for MM6 model specific things.
The first thing to do is check for blown fuses. The manual shows locations of all fuses. Don't just reply on visual inspection of fuses, use a meter to test them as sometimes they can look good but be blown.
It looks like I have the manual and the supplemental in one book.
I checked the fuses. One was blown! That took care of the no power. Unfortunately, now the top (A- K) and bottom (1-0) rows of buttons are able to be pressed in and just hold in. The middle( L- V) immediately release. The relay doesn't seem to be holding
